Light Mix is preventing GPU rendering
  • Light Mix is preventing GPU rendering
    Hi, has anyone else experienced this issue. When I add Light Mix as a render element I'm unable to render using GPU or CUDA. I get ERROR [V-RAY] [GPU light cache] Could not allocate buffer of size. Its very frustrating especially as it worked once and I found it really useful, now it wont at all.
    Hello paul_rogers,
    Please note that adding Render Elements will require more memory during render and the error you are getting indicates that you have run out of memory.
    Regarding Light Mix are you adding it in the default mode Group by Individual Lights?
    If yes, try changing it to Group Instances and track your memory in the VFB > Stats.
ID:	1172216 Click image for larger version
    Apart from that please share your GPU model and what drivers do you have installed. ​
    Natalia Gruzdova | chaos.com
