VrayFur BUG
  • VrayFur BUG
    Vray GPU:
    Vray CPU:
    What is wrong with this object? Or what is wrong with Vray GPU renderer?
    V-Ray 6.10.02
    Max 2020 scene: hair BUG.zip
    I'm getting a Missing OSM (missing modifier) hence weird results in both GPU and CPU. I presume this is for the vertex painting. Are you using another plugin for it? I don't see a difference between CPU and GPU with the 3ds max native VertexPaint.
      Sorry for late response.
      Originally posted by hermit.crab View Post
      I'm getting a Missing OSM (missing modifier) ....
      This is VRayFurStyler.
        OK. I did some troubleshooting and it seems, in GPU the object must be collapsed to i.e an Editable Poly or Editable Mesh for the VRayFurStyler to work properly. I presume this is normal, but I need to speak with the devs first.
        EDIT: I cannot reproduce it on a fresh scene, however. VRayFurSyler does not allow me to paint on uncollapsed objects. I'm interested in how you came to this result.
