Hi. I have a fairly simple exterior scene (screenshot below) and with all objects visible I get 10-20 sec long pauses when changing an object's position. This can't be normal, can it? I don't even have displacement turned on. It's very hard to try out different scenarios with such long pauses when moving stuff around. The only error I'm getting in the log tab is something about the EdgesTex map. Let me know if you need the scene.
I'm getting 10-20 second long pauses in IPR when changing object's position?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Hi Alex_M,
Best would be to forward the scene via our contact form so we can investigate and get back to you. Make sure to mention this thread in the subject - much appreciated!Nikoleta Garkova | chaos.com
Hi, nikoleta.garkova. I've just sent the scene. The ticket number is 114293. Thanks!Aleksandar Mitov
96GB DDR5
Thank you!Aleksandar Mitov
96GB DDR5
