Applying a material override to my proxy makes the rest of the object black
  • Applying a material override to my proxy makes the rest of the object black
    Hi. I've got a proxy that I want to apply a material override to. When I do this, the rest of the proxy object turns black. Is this a bug or is this feature not supported by the GPU engine yet?
ID:	1180207 Click image for larger version
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    The material override should work in V-Ray GPU. If you override another material does it turn black too?
    Tanya Todorova
    QA
      Yes, it does. Here's an example with another proxy object.
ID:	1180250 Click image for larger version
      Aleksandar Mitov
      96GB DDR5
        Are you using Multi-Sub object material as override?
        Tanya Todorova
        QA
          No, I'm not. I'm using a V-Ray material which is not part of a Multi-Sub object material.
          Aleksandar Mitov
          96GB DDR5
            Could you send the vrmesh file to tanya.todorova@chaos.com?
            Tanya Todorova
            QA
              Sure. Should I send it through the ticket system or a direct email message?
              Aleksandar Mitov
              96GB DDR5
                It's best to use the contact form. Please, mention the thread in the email.
                Tanya Todorova
                QA
                  Done! Ticket number is 114161.
                  Aleksandar Mitov
                  96GB DDR5
                    Logged as VGPU-6162 and our developers are looking into it. Thanks for the scene!
                    Tanya Todorova
                    QA
