V-Ray GPU Rendering Freeze UI does not respond
  • V-Ray GPU Rendering Freeze UI does not respond
    V-Ray GPU Rendering Freeze UI does not respond even after waiting for hours also no response in the frame buffer that says "preparing global light manager..." can somebody help me.
    Tried to switch back to V-RAY 5 same problem.
    Tried Driver Clean Uninstall using Display Driver Uninstaller V18.0.6.4
    installed the latest Driver same problem.
    Kindly Check Screen Shot
    CPU: i7 7700K.
    GPU: RTX 3060Ti Founders Edition.
    Ram: 32GB.​
    Hi, thanks for posting. What happens if you render in V-Ray CPU? For this to happen in a simple scene there most likely is an issue with your setup. Try to reinstall everything, 3ds Max, V-Ray, drivers. If nothing helps please open a support ticket so we could possibly meet in a team viewer session.
    Vladimir Krastev | chaos.com
