Erro-There is no device available for rendering! NEW RTX 4090 card
  • Erro-There is no device available for rendering! NEW RTX 4090 card
    Today, 11:02 PM
    Hi team - Just bought a RTX 4090 Asus Tuff.
    Vray does not want to render in RTX mode. Can in Cuda and CPU mode.
    When I test my card on D5 render in full RTX mode it works fine.
    Please help. is it a driver issue?
    I have installed the latest Studio driver 535.98.
    Run Vray 5.2
    CPU i9 13900KF
    64 GB Windows 10
    Thank you.
    Waldo​
    Run Vray 5.2
    CPU i9 13900KF
    64 GB Windows 10
    Thank you.
    Waldo
      Hello waldob,
      Please provide following information so we could investigate your issue further:
      • First, please install the current recommended drivers 531.41 version. You can find this information on the top of this page: https://www.chaos.com/vray-gpu. Please note that this is the version that is tested and approved by the developers and how it works with V-Ray, so it can be different from the latest version released by NVIDIA.
      • Then please run V-Ray Benchmark in V-Ray RTX mode and share a screenshot of your results.
      • Apart from that please let us know the exact V-Ray version you have currently installed (Extensions>V-Ray>Help>About V-Ray).
      • Also please check GPU Device Selection settings, example:
        Click image for larger version  Name:	GPU_Device_selection.jpg Views:	0 Size:	31.9 KB ID:	1183369
      ​Also please kindly note that we have merged your topic from SketchUp section into this one in the GPU section.
      Natalia Gruzdova | chaos.com
        Thank you so much Natalia - Should I download the Game ready driver or the Studio 531.41. I have downloaded Vray benchmark - will test it now.
        Waldo
          I am running Vray 5.20.06 for Sketchup 2021.
          Have installed 531.41
          Benchmark test results
            Natalia - all is working now!!
            Thank you so much for your support.
            Waldo
              Natasha - Sorry. It was working then I got this error.
              6/13/2023 11:12:36 AM Error [V-Ray] There is no device available for rendering!
              6/13/2023 11:29:00 AM Error [V-Ray] Exception in CORE: Internal error. Please save and restart as soon as possible!
                Thank you waldob for sharing your V-Ray Benchmark scores. Unfortunately the score you get for both CUDA and RTX is significantly lower than expected.
                You can compare your results on V-Ray Benchmark results page to other user-submitted results with the same hardware configurations. For example, the average score for one NVIDIA GeForce RTX 4090 is 5000 vrays: example.
                This difference can indicate some hardware issues, which is why I would like to suggest you to test your GPU with other available GPU benchmarking software. You can find some useful suggestions in this article.
                Another possibility is a driver issue that was discussed in this forum thread. You can test installing older drivers as suggested in this post and running V-Ray Benchmark again.
                While testing V-Ray Benchmark please also run a TechPowerUp GPU-Z to check GPU temperature and record a video with GPU-Z Sensors Tab opened.
                If possible, also test current 531.41 with V-Ray Benchmark and GPU-Z as well and let us know the temperatures (video will be most helpful).
                We recommend installing Studio drivers. Also, during installation to ensure deleting previous versions you can click on Custom (Advanced) installation > Perform a clean installation.
                Please see examples below:
Name:	NVIDIA Custom (Advanced).jpg
ID:	1183394 Click image for larger version
Name:	NVIDIA Perform a clean installation.jpg
                Exception in CORE: Internal error. Please save and restart as soon as possible!​
                Can you please also test a new empty scene and any other of your scenes? Do you get this error in every scene?
                  Morning Natasha - I have installed driver 528.49 and I have installed driver 531.41(clean installation)
                  Please scores below. Not much difference.
                  Also I have record the Benchmark test displaying the GPU temp. It runs around 47degrees. Starts at 97 and drops down after 3 seconds.
                  When I open Wondershare Flimora to edit the clip I noticed that the the GPU temp was about 80 ish degrees.
                  How can I send you the GPU temp clip it is 60mb.
                  Also need to test other benchmark software still.
                  Thank you.
Name:	RTX test_Clean installation.png
                    Natalia - please see also bench mark test for D5 and comparisonClick image for larger version
Name:	GPU D5 test_ driver 31.0.15.3141.png
ID:	1183480 hardware from other users.
                      Hey waldob
                      Like what my colleague Natalia suggested, your scores for both V-Ray RTX benchmark and D5 render Benchmark is lower than expected. Nearly half of what you should expect out of your GPU. This is because of a performance bug in the current drivers, we have been working closely with Nvidia to find a solution. This performance bug happens on GPUs connected to monitors, which I think it is in your case.
                      • Please download this driver
                      • Do a clean install like the screenshots Natalia posted above
                      • Restart your machine when the new driver is installed(important)
                      • Go to Nvidia Control Panel, Manage 3D settings, change Power Management mod to Prefer Maximum Performance then click Apply. See the screenshot attached
                      • Run the Benchmarks again and post the results here
                      • If you still have low scores we will schedule a remote session with Team Viewer to check your setup
                      Thank you and have a nice day!
                      Best,
                      Muhammed
                      Muhammed Hamed
                      V-Ray GPU product specialist
                      chaos.com
                        Hi Muhammed,
                        THANK YOU SO MUCH. Fantastic advice. Look at my scores now I have spend allot of money on my new upgrade - finally can use it to its full potential.
                        Keep up the good work.
