Calculating CPU glare
  • Calculating CPU glare
    MAX freezes when calculating glare. This seems to be constant.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi, thanks for posting. Are you using V-Ray GPU or V-Ray CPU for calculating the glare? You are posting in the GPU section. Could you give us a bit more details about your workflow?
    Please use screengrabs if possible. Is this issue happening in every scene even a new simple scene? If you have troubles with a specific scene please send it over so we can review it.
    Vladimir Krastev | chaos.com
      GPU is calculating glare. It has happened several times; freezing MAX while calculating.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Hi
        Please use screengrabs if possible. Is this issue happening in every scene even a new simple scene? If you have troubles with a specific scene please send it over so we can review it.​
        You could also open a support ticket trough the support contact form where we can share scenes in an easy and secure way and even meet for a team viewer sessions if we need to do so.
          Ifit happens again, I will. Thank you!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Ok, thanks for the update.
