Hi, thanks for posting. What DCC are you using? (for example is it 3ds Max). I am not sure what do you mean? Could you explain you issue in a bit more details? On my setup, using 3ds Max 2024 and V-Ray 6.10.08, VRayBitmaps are visible on the backside of the faces in viewport and render.
The OP is pointing out that it does not work when the box is not ticked, which should make the back side invisible, which can be useful in some situations.
Only scanline works in this regard.
The Vray option is to have a 2sidedmaterial with the back side using a vraycolour set to black
I am switching if off, watch the video. With the checker off it shows the grey diffuse colour on backside faces but only in render. Viewport does not work.
