Stopping a GPU render
  • Stopping a GPU render
    I have posted this before, but there was no solution. Stopping a GPU render when doing an exterior isn't possible. I can wait 1/2 an hour and have to kill MAX. There has to be a solution. Otherwise, GPU is useless for these scenes—nothing crazy, just an exterior scene with Forest Pro, Railclone, and some displacement.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi, thanks for posting. Are you sure you have enough video memory? Are you able to save your render output? What is the hardware during the time you are waiting for render end? What is the utilisation of the CPU, GPU, storage devices? Is you 3ds max frozen during the time you have to wait for render end?
    Which button do you use to stop the render - the "stop", the "cancel" or the VFB stop render icon? Do you have Denoiser active? What messages do you get during the waiting period, could it be the denoiser working on the image?
    Vladimir Krastev | chaos.com
      I have an RTX 4090. I pick the cancel to try and kill it. I have 128 GB of RAM and don't come close to maxing it out. I'll have to peek at the video ram next time. Yes, MAX says not responding, but that is nothing new. If I look at my screen wrong it sometimes goes into not responding.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Hey!
        I'm able to reproduce this on my side, it happens with complex scenes usually with many scatter objects. We will pass to devs to take a look
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          I have this as well, cant cancel a render half the time when using IPR in GPU . Drives me INSANE. This particular scene has a Phoenix fd grid, and using denoiser if that's relevant. Pushing stop, pause, esc, etc all doesnt work. Scene is still responsive , but VFB stops updating and have to quit max.
            I can only use GPU for interior work. For exteriors, it is too frustrating to use.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Has this been solved? I'm still dealing with the same issue
                It is fixed yes, please stick to CUDA mode for your rendering. See if that makes things better
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
                  Yes, it has been fixed. For the last month, I have been using GPUs for all my work. I added a second 4090 since it has been going so well.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
