Gpu dr
  • Gpu dr
    When I pick DR when using GPU, nothing happens. If I uncheck DR, it renders fine. Is there something I have to do? I have one render node and I ran the setup on that machine.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi, thanks for posting. Please read this docs page and complete the steps there - https://docs.chaos.com/display/VMAX/...uted+Rendering
    Vladimir Krastev | chaos.com
      Does it have to be CUDA? CUDA has always run slower for me. I use RTX, which is faster by far.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        It should work with CUDA and RTX. Were you able to complete your distributed rendering setup for GPU and does it work?
          No, it doesn't work. When I pick DR for GPU, nothing renders.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Have you completed the steps in the articles from my previous post? Try a new simple scene. For instance create a few default objects like boxes or teapots and a simple dome light with no texture. Raise the resolution and the sampler settings a lot in order to give a bit of time for the slave computer to join rendering before the frame is rendered. If this does not work, please contact the technical support for a team viewer session - https://support.chaos.com/hc/en-us/requests/new
            In case a scene like the simple one described above renders successfully with distributed rendering, please send us your production scene that does not render for a test over the support contact form (linked above).
