3dsmax fluids take long to render with vray gpu
  • 3dsmax fluids take long to render with vray gpu
    Hello,
    I have one scene with 3dsmax Fluids, which takes very long to just start vray GPU processing. Rendering goes fine btu preprocessing takes very long. It doesn't happen in other renderer.
    Where can I email the scene?
    Regards,
    Jignesh
    Hi, thanks for posting. What versions of V-Ray and 3ds Max are you using? Do you have the same issue with a new simple scene? Do you have the same issue with V-Ray CPU? You can send the scene here or trough the support contact form. If you choose the contact form please add a link to this thread in your message.
    Vladimir Krastev | chaos.com
      It renders faster with Fluid loader inside 3dsmax but not if there is maxfluids object. I will share the file anyway.
        I emailed the scene at muhammed.hamed@chaos.com​. Can you please take from him?
