Crash When Rendering with Isolated Geometry
  • Crash When Rendering with Isolated Geometry
    When isolating some geometry and rendering, max will crash. It happens with max 2023 and 2024, I'm using V-Ray 6 GPU Update 2.
    It may be a max issue but, I'm not sure.
    I only noticed it recently in the last 2 to 3 months.
    Thanks,
    N.
    Hey NorthVisualStudio,
    Does the crash happen in GPU IPR or Production rendering?
    Are there any specifics as to what kind of objects we need to isolate? I am testing on a simple setup and cannot yet reproduce crashes, so it would be super helpful if you can add more details or even send a scene with the crashes reproducible.
    You can also open up a support ticket and forward a 3dsmax minidump so we can investigate possible causes if it's not consistently reproducible. It should be named 3dsmax_minidump.dmp and be located in your temp folder (type %TEMP% in the windows explorer address bar). Much appreciated.
    Nikoleta Garkova | chaos.com
      Hi Nikoleta,
      It's GPU production rendering and there are no common items that would lead me to believe there is a pattern.
      I will send a max file and the log/mini dump files as a support ticket.
      Thanks, N.
