tyflow gpu rendering
  • tyflow gpu rendering
    the setup i use for a shadow pass. I make my objects renderable but not visible. With this alpha I can use it inside a grade node in nuke to create a shadow.
    in gpu, the tyflow objects are still visible even if I right click them to not make them visible.
    https://youtu.be/F7ctTiu43Gg
    Try adding an Edit Poly modifier on top of the tyFlow object and see if that makes the "visible to camera" to work.
