VRay GPU 6.2 3dsMax 2024 Bitmap colour space support
  • VRay GPU 6.2 3dsMax 2024 Bitmap colour space support
    I'm not able to make VRay GPU respect colour space of native 3dsMax Bitmap loader.
    Bug or did I miss something?
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    Hi, thanks for posting.
    Could you explain your issue in a bit more details, if possible with examples?
    What colour space are you using? Are you testing the 3ds Max's aces colour management?
    Vladimir Krastev | chaos.com
      3dsMax color managed with OCIO (default one or any custom config I tried)
      rendering space: both sRGB and ACEScg
      native Bitmap texture loader is shown correctly in the viewport according to colour space picked while loading the texture (so gamma corrected srgb or AP1 in my case) and view transform
      VRay renders the Bitmap correctly
      VRay GPU renders the Bitmap incorrectly, always interpreting it as Raw.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Hi, the issue is reproducing in a simple scene. We reported it under VMAX-13903 in our bug tracking system. We will notify you when the fix is ready.
        Until then please convert your Bitmaps to VRayBitmaps.
          Thank you.
          I'm looking forward to any available info on that.
          VRayBitmap needs VRayOCIO node to have access to 3dsMax's OCIO config. not ideal.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
