Tyflow Tycache instancing not working with vray gpu
  • Tyflow Tycache instancing not working with vray gpu
    Hello,
    It seems tyflow instancing is not working with vray gpu. I exported tyflow particles (without mesh) to tycache and then in Tycache I did reverse time remapping and turned on mesh override. I have vray interface also turned on and it is set to instances.
    But vray gpu is very slow to render and on each next frame render process time increases.
    I tried nightly and stable versions both. Both has same issues with vray gpu. Can anyone please confirm it?
    Regards,
    Jignesh
    Does it happen on the CPU? What you can try is enable tyCache's particle interface (tyCache>Elements>Particle processing) and instance the object through VRayInstancer instead. Compare if there's a render time difference.
      it happens with vray gpu only. With vray gpu tycache instancing works. I will try what you suggested and let you know.
