Loading bitmaps... is a deal breaker for my GPU rendering. No textures are larger than 2K, all converted to TX files, and for any changes, I sit and stare at Loading bitmaps for 2-3 minutes. Am I doing something wrong?
Loading Bitmaps...
Loading Bitmaps...
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Hi Bobby,
I'm able to reproduce this on my side with the scene you sent me last week, it seems to slow down after playing with the scene for a while. Is it any better on your side if you swap to the CUDA engine?
FYI we are making drastic changes to this stage, uploading bitmaps, to make it faster and more efficient.
Best,
MuhammedLast edited by Muhammed_Hamed; 22-06-2024, 11:09 PM.
- Likes 1
I'll try Cuda and let you know.Bobby Parker
phone: 2188206812
- Windows 11 Pro
There is no difference. I really can't use GPU rendering. I have a pretty simple scene, and it takes five minutes to load bitmaps.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am ready to call it quits with GPU. I hit render, and it renders fine and fast. I hit render, and I got Loading bitmaps for 21 minutes; same scene and nothing changed. A phone call would be great.Bobby Parker
phone: 2188206812
- Windows 11 Pro
- Likes 1
Follow-up
The issues was about Compressed Textures, with many high-resolution bitmaps in the scene it takes a lot of time to process and upload the textures. Swapping to Full Size textures or "Use System Memory For Textures" solved the issue. Time to first pixel is now within 30 seconds
- Likes 1
