Slow GPU
  • Slow GPU
    Every once in a while, I pop back into GPU rendering. It is slow on even the most basic scenes without materials. I have tried RTX and CUDA but it does not make a difference. I have a second 4090 going in today, but I feel I am wasting my time and money.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hey Bobby,
    You shouldn't use Low Priority thread for your hardware, this option is only meant to be used for mid/low end GPUs that struggle to keep up with rendering + viewport and UI. After that, use 4000 LC Subdivs for your scene, the reason for changing this value is that your scene relies mostly on indirect lighting for illumination, in addition you are rendering in 4k resolution(higher resolutions need high LC Subdivs)
    Also make sure you disable your Render Elements until you do your final frame rendering
    One advice is to use GPU-Z in the background, pay attention to your Board Power Draw. For an RTX 4090 you need to see around 250-300 Watts, if it is any lower this means that your GPU is not working at its full capacity
    I will write a support article about GPU usage, I think it will be helpful
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      My board Power Draw is (highest) 204W. What do I need to do?
      Would this be a more suitable power supply - https://www.corsair.com/us/en/p/psu/...-cp-9020070-na
      Click image for larger version  Name:	GPUZ.gif Views:	0 Size:	18.2 KB ID:	1210098
      Click image for larger version  Name:	IMG_1594.jpg Views:	0 Size:	397.9 KB ID:	1210094 Click image for larger version  Name:	IMG_1593.jpg Views:	0 Size:	690.2 KB ID:	1210095 Click image for larger version
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        It has jumped to 260W but only uses 40% of the GPU load. <EDIT> It looks to be jumping to 99% at times. However, the board Power Draw isn't going over 300W.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Could you please try with our Benchmark tool, CUDA engine
          See what Power draw you get on both cards
          Best,
          Muhammed
          Muhammed Hamed
          chaos.com
            I wrote an article about this here
            I hope it will be helpful
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
