edgetex width multiplier not supported
  • edgetex width multiplier not supported
    The gpu supported features doc doesnt mention that the width/radius multiplier feature isnt supported. Its greyed out for me...is this correct?
    e: info@adriandenne.com
    w: www.adriandenne.com
    Hi, thanks for posting. It is grayed out on my end as well. I will see what is going on and get back to the thread.
    Vladimir Krastev | chaos.com
      Hi, we will update the documentation. Do you need this parameter in V-Ray GPU? Could you give us an example of your work with V-Ray GPU where you needed this parameter enabled.
        I can. It's a pretty crucial element of that shader I'd say. I have a scene/s where they crash using ipr cpu for whatever reason, so I had to switch to gpu, which works fine, though of course I lose all my edgestex bumps,
        meaning I have to then model all the imperfections or do without, which isn't good.
          yeah i was hoping to use it for edge imperfections.
            Thanks for your input francomanko and fixeighted
            I added your votes to this new request, if it doesn't take a lot of time to implement we will work on it soon
            Best,
            Muhammed
            Muhammed Hamed
            V-Ray GPU product specialist
            chaos.com
              thanks for that, much appreciated.
