Render Mask with PNG texture renders a black image if I use DR
  • Render Mask with PNG texture renders a black image if I use DR
    Hello,
    V-Ray GPU is rendering a black image if I use a Render Mask with a PNG texture and Distributed Rendering is enabled. I tried both RTX and CUDA. If I use only the GPU of my machine, then the image renders fine. It happens even with the simplest scenes. Is this a bug or limitation of V-Ray GPU? Nothing about this issue/limitation is mentioned in the official help page. Both the local PC and the remote render server are using the recommended GPU driver.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 566.14
    Mind if you send (or attach) the scene so we can troubleshoot?
      Sure. See attached.
      Aleksandar Mitov
      96GB DDR5
        Reproduced and logged (internal bug-tracker id: VGPU-6521).
          Thanks!
          Aleksandar Mitov
          96GB DDR5
