I'm using distributed rendering but the slave machine says rendering image 0.00% Does this mean the second machine is doing nothing? See image
Distributed rendering slave marks 0.00%
Hi, thanks for posting. You could use the VRayDRBucket render element. It shows the name of the rendering machine that rendered any particular bucket when distributed rendering is used. Also you can disable the checker "use local host" and start a render. If it renders then your slave is rendering it since the machine you start the job from is excluded.
Thank you! I see all my PCs registering in the buckets. I was confused as to why the render server says 0.00%
The problem I now have is whenever I use distributed rendering my denoise elements do not render correctly. I keep seeing this error every time I run the denoiser, which does not happen when I use a single PC to render.1 Photo
