Vray GPU Distributed Rendering cannot connect to PCs
  • Vray GPU Distributed Rendering cannot connect to PCs
    Hi I have problem with connecting to slaves when I want to render with gpu distributed. I can connect with CPUs but not GPUs. I use same IPs but different port as in documentation. Tried to turn of firewall but that didnt help.
    I got message in log: Could not connect to host. Connection timeout.
    im using max23 and vray 62006
    Any idea what could I try ?
    Thanks for help
    Hi, thanks for posting. Do you have this issue with a new simple scene or just in a specific scene?
    Please go trough you setup once again. Here is a step by step guide for distributed rendering - https://docs.chaos.com/display/VMAX/...uted+Rendering
    Make sure you have selected the correct devices you want to use for distributed rendering - https://docs.chaos.com/display/VMAX/...seforRendering
    Vladimir Krastev | chaos.com
