Poor Results
  • Poor Results
    I am using GPU progressive, and the results are not good. Here are the renders. They are 4K, with a noise threshold set to .003 and .005 for the light cache. Zoomed out, they aren't bad, but zooming in, they fall apart. As you can see, I have turned off the denoiser. How can I try to fix this?
Name:	Screenshot 2024-08-20 113130.png
ID:	1214294 Click image for larger version
Name:	Screenshot 2024-08-20 113038.png
ID:	1214293 Click image for larger version
Name:	Screenshot 2024-08-20 113053.png
ID:	1214292 Click image for larger version
Name:	Screenshot 2024-08-20 113116.png
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I am by no means an expert when it comes to GPU, but have you increased the Max number of samples? If I recall GPU has a default samples limit that is too low to actually achieve the noise threshdolds you are using. I seem to recall the logs saying something like Rendering terminated because sample limit reached, as opposed to continuing under the noise limit is reached. It looks like undersampling with denoising.
      Hey Bobby!
      Increase the samples limit to 5000, and GPU LC Subdivs to 3000. Maybe noise threshold of .01 and Intel's denoiser
      What are the render times?
      And do you see any errors in log? what about GPU memory usage during rendering?
      Best,
      Muhammed
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Have you guys considered increasing the default sample limit for GPU? Not sure I understand the motivation behind it being so low. In CPU there is no such limit, other than max subdivs.
          It has a big impact on render times depending on the scene, hence we decreased it from 5000 to 2500 in V-Ray 6
          2500 is a good starting point, and should be doubled then tripled if the user wants a cleaner result
          The standard V-Ray CPU works in a different way, and will not be as slow if you use high Max Subdivs
          Muhammed Hamed
          chaos.com
            When I raise it that high, I am at CPU render times.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Originally posted by Muhammed_Hamed View Post
              Hey Bobby!
              Best,
              Muhammed
              I'll be playing more with the settings when the client has feedback.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Okay, super clean in 15 minutes using your recommended settings.
                • Samples limit 5000
                • LC Subdivs 3000.
                • Noise threshold of .01
                • Intel's denoiser
                Thank you!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  15 minutes for this kind of scene in 4k is impressive!
                  Thank you for sharing! I will update the documentation about sampling for GPU, it could be better
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
