Texture in Bump map of VRayNormalMap
  • Texture in Bump map of VRayNormalMap
    Hi
    I try to combine a normal map and a bump map with VRayNormalMap but it doesn't seem to work with GPU. It works fine if I render with CPU. Is this a bug or just a "feature"?
    Mikko
    Hi, thanks for posting. Could you explain your workflow in more details? A screengrab of your shader network or a test scene would be best.
    Vladimir Krastev | chaos.com
