two machines two GPU network rendering
  • two machines two GPU network rendering
    Hi all,
    My work machine has a 4080 RTX
    My slave machine has a 2060 RTX
    I hit render on my work machine and only the GPU on the slave machine is used
    Means, the 2060 is used (100%) and not the 4080
    Use local host is on. I've tried CUDA engine in the setttings as well as RTX. Same result.
    Any idea why?
    thank you
    small update
    Rtx 2060 win 10 max 2025.3
    Rtx 4080 win 11 max 2025.3
    when 4080 is the slave machine, both gpu are rendering
    when 2060 is the slave machine, only the 2060 is used
