Vantage - Issue with setting up cameras
  • Vantage - Issue with setting up cameras
    Hello, I am setting up cameras with a simple front forward movement of travel but Vantage doesn't follow that movement and create completely crazy sequences. I just updated to the latest Vantage version.
    I am the only one with this issue?
    Do you work inside Vantage or this is a live link render?
    Could please send us a reproducible scene tile and steps to reproduce to our support portal: https://support.chaos.com/hc/en-us/requests/new
    A short video(screen recording) that shows the issue will be very helpful.
    Please use the Vantage forum section for issues related to Chaos Vantage.
    Tashko Zashev | chaos.com
      Hello Tashko, thank you for your answer. I reverted back to Vantage 2.5 to solve the issue as I work inside Vantage and not through live link. I saw that the latest update had a fix about cameras' FOV which might be a fix to my problem. I will send a video through Support.
        Yes, you can try 2.6.2 with the latest Camera fixes when render animations. You can provide an update here or via our ticketing/help center.
