When using Vdenoise with Nvidia and Temporal mode, its blending the first frame with the last frame on Chaos recommended Nvidia driver 561.09 and creating smudges.
It does not happen on the previous Chaos recommended Nvidia Driver 551.86 and all frames load properly into Chaos Player
On the latest Nvidia driver 566.14, it does not blend the first and last frame and does not cause the smudging but it does not name the first frame properly leaving out '_ocl' in the file name so you can't load the entire sequence like you can with driver 561.09 without renaming the first frame.
