rendering might be slower
  • rendering might be slower
    [09:50:42.188] Warning : Num samples per thread reduced to 32768, rendering might be slower
    All textures are converted to 2K-TX, and I am getting the above error. These scenes never had memory issues earlier. Anything to do?
    GPU 0
    NVIDIA GeForce RTX 4090
    Driver version: 32.0.15.6614
    Driver date: 11/6/2024
    DirectX version: 12 (FL 12.1)
    Physical location: PCI bus 8, device 0, function 0
    Utilization 0%
    Dedicated GPU memory 9.4/24.0 GB
    Shared GPU memory 0.3/64.0 GB
    GPU Memory 9.8/88.0 GB
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Rebooting Windows solved it, so V-Ray isn't releasing RAM.
    Before the reboot, the est render times were 2-3 hours. Now, it is 35 minutes, which is what I would expect for this scene.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      yeah im pretty sure im having the same issue since vray7. Quiting 3dsmax releases it for me.
      e: info@adriandenne.com
      w: www.adriandenne.com
        If you're using RTX as a GPU engine - this is a known issue (internal bug-tracker id: VGPU-6714) concerning a memory leak when rendering animations with RTX. Main thread here. To confirm - try rendering with CUDA and see if there's a difference.
          i think my issue might be something else memory related so i'll create a new post if thats ok.
            Please, go ahead.
