rtx or cuda same behaviour, same with the latest nightlie, updated the FP to latest as well (one version up), recommended drivers, max 2024 updated to latest... on which side is the issue chaos or itoo? Should I send my file somewhere? ps: scene is quite heavy but stat says around 12gb from 22 gpu ram used. PS: the objects that are not updating are the ones used as vraydistancetex objects.
animated sequence (only cam and sun moving) 4 frames some forestpack objects disapper on the second frame
