use the command line to start vray gpu. Choosing RTX rendering will generate the following log. What is this error?
  • use the command line to start vray gpu. Choosing RTX rendering will generate the following log. What is this error?
    Help, use the command line to start vray gpu. Choosing RTX rendering will generate the following log. What is this error? How to solve it?
    [2025/Feb/21|17:50:46] [157 MB] Finished loading plugins.
    [2025/Feb/21|17:50:47] [160 MB] Reading scene file "intro.vrscene"
    [2025/Feb/21|17:50:47] [160 MB] C:\intro.vrscene: done [ 0h 0m 0.0s]
    [2025/Feb/21|17:50:47] [160 MB] File version is 1.00
    [2025/Feb/21|17:50:47] [160 MB] Scene file parsed successfully in 0.0 s.
    [2025/Feb/21|17:50:47] [160 MB] warning: Unknown property "enable_mask" in object "settingRTEngine"
    [2025/Feb/21|17:50:47] [160 MB] Scene created successfully.
    [2025/Feb/21|17:50:47] [160 MB] Objects in scene: 180
    [2025/Feb/21|17:50:47] [160 MB] Starting render sequence.
    [2025/Feb/21|17:50:47] [160 MB] Setting number of rendering threads to 12.
    [2025/Feb/21|17:50:47] [160 MB] warning: Max sample level set to 0 - rendering could take longer than expected. Consider setting a value to decrease the render time (i.e. 10000).
    [2025/Feb/21|17:50:47] [160 MB] Progressive RPP must be disabled when Adaptive Lights are used. Disabling progressive RPP
    [2025/Feb/21|17:50:47] [160 MB] GI engines: 'Brute force' and 'Light cache'
    [2025/Feb/21|17:50:47] [160 MB] Preparing renderer...
    [2025/Feb/21|17:50:48] [260 MB] CUDA renderer requested.
    [2025/Feb/21|17:50:48] [260 MB] 1 plugin(s) loaded successfully
    [2025/Feb/21|17:50:48] [260 MB] CUDA renderer plugin successfully loaded from "C:\Program Files\Chaos\V-Ray\Standalone for x64\bin\rt_cuda.dll"
    [2025/Feb/21|17:50:48] [260 MB] CUDA renderer plugin instance successfully created.
    [2025/Feb/21|17:50:48] [260 MB] EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance.
    [2025/Feb/21|17:50:48] [261 MB] Using 5 threads per GPU device
    [2025/Feb/21|17:50:48] [261 MB] Tiled texture cache set to 1000 MB
    [2025/Feb/21|17:50:48] [261 MB] Creating bitmap manager
    [2025/Feb/21|17:50:48] [261 MB] Bitmap manager created.
    [2025/Feb/21|17:50:48] [261 MB] Preparing scene for rendering...: done [ 0h 0m 0.0s]
    [2025/Feb/21|17:50:48] [261 MB] Light tree is enabled with clamp coefficient 0.1 and even split coefficient 0.5.
    [2025/Feb/21|17:50:48] [345 MB] Using normal thread priority.
    [2025/Feb/21|17:50:49] [353 MB] Using 5 threads per GPU device
    [2025/Feb/21|17:50:49] [353 MB] Bucket size increased to (128, 12 in order to improve GPU utilization.
    [2025/Feb/21|17:50:49] [353 MB] Max ray intensity is enabled: rendered result may have incorrect brightness.
    [2025/Feb/21|17:50:50] [353 MB] Using 5 threads per GPU device
    [2025/Feb/21|17:50:50] [353 MB] ========================
    [2025/Feb/21|17:50:50] [353 MB] Starting frame 1.
    [2025/Feb/21|17:50:50] [353 MB] Preparing scene for frame...: done [ 0h 0m 0.0s]
    [2025/Feb/21|17:50:50] [353 MB] Compiling geometry...: done [ 0h 0m 0.0s]
    [2025/Feb/21|17:50:50] [353 MB] Using Embree ray tracing.
    [2025/Feb/21|17:50:50] [353 MB] Using per-object Embree static geometry.
    [2025/Feb/21|17:50:50] [353 MB] Embree instance tree uses 0.00 MB.
    [2025/Feb/21|17:50:50] [353 MB] Scanning scene for light plugins.
    [2025/Feb/21|17:50:50] [353 MB] 1 lights found.
    [2025/Feb/21|17:50:50] [353 MB] Using adaptive light evaluation with 8 lights.
    [2025/Feb/21|17:50:50] [353 MB] Using 1.60 MB for adaptive lights buffer
    [2025/Feb/21|17:50:50] [353 MB] GPU render kernel type: 2
    [2025/Feb/21|17:50:50] [353 MB] Initializing OptiX renderer...
    [2025/Feb/21|17:50:50] [353 MB] Querying for OptiX devices...
    [2025/Feb/21|17:50:50] [390 MB] PTX file generated with CUDA Toolkit v12.0 for CUDA compute capability 5.2.
    [2025/Feb/21|17:50:50] [390 MB] Compiling OptiX with full optimizations.
    [2025/Feb/21|17:50:50] [390 MB] Device[0]: NVIDIA GeForce RTX 2080 Ti (WDDM mode) has compute capability 7.5. PCI Bus ID: 0000:00:07.0
    [2025/Feb/21|17:50:50] [390 MB] Setting CUDA stack size to 12000 (728 MiB used for stack)
    [2025/Feb/21|17:50:50] [551 MB] Using 5 threads per GPU device
    [2025/Feb/21|17:50:50] [551 MB] Number of CUDA devices: 1
    [2025/Feb/21|17:50:50] [551 MB] nVidia driver version: 572.16
    [2025/Feb/21|17:50:50] [551 MB] warning: Checking CUDA driver version: 5001: Installed driver version (572.16) is newer than the latest verified one (566.14)!
    [2025/Feb/21|17:50:50] [551 MB] Initializing environment kernel
    [2025/Feb/21|17:50:50] [551 MB] error: Failed to build Embree tree for dynamic mesh: [EmbreeStaticMeshTree::build] 1: Committing (join) scene failed!
    [2025/Feb/21|17:50:50] [551 MB] error: Failed to build Embree tree for dynamic mesh: [EmbreeStaticMeshTree::build] 1: Committing (join) scene failed!​
    Mind if you send the .vrscene so we can troubleshoot?
      Thank you for your reply. I have never sent any files to you before. How can I provide you with downloadable links?
        Use the contact form here.
