White dots on render
  • White dots on render
    I have been trying to render for the past 2 days but i cant seem to get a clean render , and my setting for vray have been the same , i use rtx 3070 ti
    so i dont know what the issue might be , im only facing this issue with new vray and sketchup 2025 , and my subscription is genuine , so i dont know why im facing thse things iwill post my vray setting and the result im getting
    Try to switch the GPU mode (Cuda/RTX), maybe it helps.
      General I use LC raytrace 1 all days because it's much faster. Also using less quality max subdivs like 60 and noise threshold 0.01 plus enable a denoiser should bring the render times down. Maybe your 10min cutoff did it, but I'm not sure it's a good way.
        Hello jude_abed,
        Thank you for reaching out.
        I agree with Micha that most likely 10 minutes are not enough time in this case to clean out excessive noise. Try setting 20 or 30 minutes to test if this is the reason indeed.
        Otherwise you may also consider following settings:
        • Use CUDA render engine (CPU+GPU);
        • Set Quality to Medium+;
        • Make sure that Denoiser is enabled;
        • Remove the time limit;
        If none of the above helps let us know.
        Natalia Gruzdova | chaos.com
