VRAY GPU Lightmix slowdown!
  • VRAY GPU Lightmix slowdown!
    Hello!
    Im doing alot of retail renders and therefore love using Lightmix! to be able to control lights on the go in the VFB! I feel I have noticed an extreme slowdown with Vray gpu and using lightmix, It feels way to slow to use compared to the loss in render speed.
    I have upgraded my system recently to a 5090 system. Running all the benchmarks everything is fine - Averaging the 15k in rtx benchmark! And GPU load 100% tracked with Gpu-Z!
    I open a standard scene in 3dsmax 2025 with lightmix enabled, maybe 40 Unique lights in lightmix that needs to be controlled~ Mixed vray mesh lights, vray ies lights and regular vray lights (Plane, sphere etc.)
    When I render I get extreme GPU load spikes - Instead of maybe between between 70-100~% I would expect? I go from as low as 1% to around 80% and render speeds drop immensely! - Final render time for the frame 20min~
    WHen I render with Lightmix Disabled I get GPU load 100% and expected render speeds! - Final render time for the frame around 9min~
    Is the Lightmix really expected to slow down this much with 40 light groups?
    It happens in all my scenes using Lightmix!
    Kind Regards
