VRayMtlWrapper not supported?
  • VRayMtlWrapper not supported?
    according to this list (https://docs.chaos.com/display/VMAX/...orted+Features) the VRayMtlWrapper material should be supported in GPU mode. However it seems that the Matte properties have no effect. In CPU mode it works without issues.
    Is that a bug?
    Check out my FREE V-Ray Tutorials
    Mind if you attach a sample scene so we can have a look?
      there are 2 issues:
      1. The Matte doesn't work unless the AlphaContribution is between -0.9 and -1. Anything apart from those values will make matte properties to not work.
      2. If the AlphaContribution is between -0,9 and -1 AND in the BaseMtl is anything else than a VRayMtl (for example a VRayBlendMtl) it will make it matte BUT the shadow options don't work.
      So the only way to have the VRayMtlWrapper work in GPU mode is to have an AlphaContribution between -0,9 and -1 AND use a VRayMtl as the BaseMtl.
      CPU doesn't have any of those issues.
      I attached you a sample scene.
      Best,
      Jonas
        1. In GPU, only Alpha Contribution -1 (Matte must be active) ̶a̶n̶d̶ ̶1̶ ̶a̶r̶e̶ ̶s̶u̶p̶p̶o̶r̶t̶e̶d̶. Decimal values, one and zero, are not. This is already logged (internal tracker ID: VGPU-2828 ).
        2. I can reproduce this and will log it (logged as internal tracker ID: VGPU-6815). Is there a specific reason to use a VRayBlendMtl for the shadow catcher?
          HI:
          1. Actually +1 also doesn't work. Only values between -0.9 and -1 as I mentioned. You can try it out. If only -1 is supported you might want to set this value internally regardless of what value is chosen in the menu as a workaround. Otherwise it will cause confusion. I only found this out after extensive testing.
          2. I have a usecase here as I'm working on a tool/script where you can easily switch between the matte and an standard option for the floorplane and the basematerial HAS to be a VRayBlendMtl. So that's how I noticed that.
          Is it a very common usecase? Probably not, but as said in CPU it works without issues. It might cause confusion you just want to create a matte shadow pass on your existing scene by putting a Wrapper in front of your existing material and no shadows show up.
            I stand corrected, it disables the Matte. It's better we support the whole parameter fully, rather than settings temporary defaults.
            Is it a very common usecase? Probably not, but as said in CPU it works without issues. It might cause confusion you just want to create a matte shadow pass on your existing scene by putting a Wrapper in front of your existing material and no shadows show up.[/QUOTE]
            Okay. Already logged the issue (edited my previous post with the ID).
              Hi, in this case I would remove the VRayMtlWrapper from the supported materials in the GPU page alltogether in the meantime. As you default the AlphaContribution to 1 (which doesn't work) it will just register as not supported to the average user. Since it shows as supported on the feature page I just wasted quite a bit of time to find out that it actually is not suported. Or make a note on the page itself.
