I usually view my renders through the vray buffer and see them in 2.2 gamma. Whilst using the demo last night, it seems that vrayRT was displaying the scene in 1.0 gamma. Is this something I have to change in RT or do I have to setup my max gamma differently now ?
display gamma in RT
Oh, ok, I see now.
What I normally do is:
(*) have 3ds Max display gamma to 2.2, sRGB button in the VFB ON, V-Ray gamma 2.2 and "Don't affect colors" to on, OR
(*) have 3ds Max display gamma to 1.0, sRGB button in the VFB OFF, V-Ray gamma 2.2 and "Don't affect colors" off.
In both of these cases the RT preview accurately reflects the rendered image. However in your case it is more complicated, I have to think a little if it can be adjusted to show the ActiveShade/regular 3ds Max RFW properly.
VladoI only act like I know everything, Rogers.
For normal rendering these are the settings I use:
Max Preference Settings
-Display Gamma 2.2
-Affect Color & Materials
-Input Gamma 2.2
-Output Gamma 1.0
Vray Frame Buffer Settings
-Frame Buffer enabled
-Get Resolution from Max
Vray Color Mapping
-Linear Multiply
-Dark multiplier 1
-Bright multiplier 1
-Gamma 2.2
Sub pixel mapping
Affect Background
These settings allow me to save out the same image I see in Vray, the only way I can find to get Vray RT to even look close is by turning on Linear Workflow but even then it's not a perfect match. All of this is being used with physical camera, sun & sky.
I see; will have to think of something for this particular configuration - basically you get the gamma correction applied twice (once from the V-Ray color mapping, and once from the 3ds Max Display gamma).
Originally posted by vlado View PostI see; will have to think of something for this particular configuration - basically you get the gamma correction applied twice (once from the V-Ray color mapping, and once from the 3ds Max Display gamma).
Originally posted by stevesideas View PostThats exactly right. I thought the config I had setup was the way most people using the LWF had it setup.Should not be too hard to correct this though.
