RT Demo DR limitation
  • RT Demo DR limitation
    I'm still playing with demo but I'm not able to run DR with two remote render servers
    It works fine with 1 local server + 1 remote server
    It works fine with 1 remote server but not more than 1
    From the help file "DR is limited to two render servers - these can be either a local render server and one additional machine, or two remote render servers"
    Maybe I'm missing some fundamental step?
    I'm on xp64 with max 2009
    server are xp32/vista 32
    vray sp3a
    Alessandro
    you will have to disable your local machine as active RT node !!
      do you mean the checkbox inside the DR settings dialog? ...if yes, sorry, I forgot to mention about it, but it's already unchecked
      Alessandro
        It worked last time I checked it; does it work when you specify either of the machines (but only one)?
          just double checked, that's the behaviour:
          1 remote server + auto start local slave CHECKED= 2+4 buckets
          1 remote server + auto start local slave UNCHECKED = 2 buckets
          2 remote server + auto start local slave UNCHECKED = 2 buckets (overlay warning DEMO limit) - my understanding is that this should work!!!
          2 remote server + auto start local slave CHECKED= 2+4 buckets (overlay warning DEMO limit)
          Each remote server works fine as far as it remains alone
          local is quad running xp64
          remote are dual running xp32
          I can add that each server could respond efficiently only using IP instead of computername
          Alessandro
            Hm, V-Ray RT doesn't use buckets (at least not in the same way as the normal V-Ray and you won't be able to see them), so maybe I don't quite understand what's going on?
              I'm sorry for my messy infos, I've written buckets instead of cores.
              I've 1 workstation quad core and 2 remote server dual core available; I've understood that RT could work different from standard DR, in particular it seems to me that it could leave the workstation free (excluded from DR), is that correct?
              So I was simply trying to test it but the following are my results:
              1 remote server + auto start local slave CHECKED = 2+4 cores
              1 remote server + auto start local slave UNCHECKED = 2 cores
              2 remote server + auto start local slave UNCHECKED = 2 cores (overlay warning DEMO limit) - my understanding is that this should work!!!
              2 remote server + auto start local slave CHECKED = 2+4 cores (overlay warning DEMO limit) - that's correct because it exceeds the demo limits
              When I'm talkin to cores I'm referencing to what I see from task manager.
              I'm pretty sure that I'm missing something
              Alessandro
