some problem when running vray rt render server
  • some problem when running vray rt render server
    Hello
    If I want to use VrayRt, for the first time I turn on my computer, before running "VRay RT render server" I need to go to windows task panel and terminate processus for :
    - Vray.exe
    - vrayrtspawner.exe
    If not I have a "10048" error.
    What can I do ?
    Thanks.
    (vrayrt, vray sp3, max2010, xp64)
    I had the same problem until I ran "Remove V-Ray RT render server as a service" from the Chaos Group folder in the Start Menu. I may have initially made the mistake of registering it as a service, thinking it worked like the V-Ray licensing service on the local host, but I guess it doesn't. Apparently, this V-Ray RT service registration option is only for the render slave machines and _not_ the local workstation running your active 3ds max session. If the V-Ray render engine service is already started in the Services app, you'll get the port 10048 opening error when you use V-Ray RT in an ActiveShade window, and the scene won't display.
      I'll try this ! Thanks )
        works fine !
