Render freezes
  • Render freezes
    I have a problem with quite a complex scene (about 2m polys, not instanced).
    After the scene and textures are loaded in RT, which takes quite a long time, the render starts and freezes immediately. It only proceeds if I keep the middle mouse button pressed. As soon as I depress, it reverts to the first, heavily pixellated image you get when RT starts a render and freezes there.
    It means I can still see my model properly rendered as I navigate the scene (as long as I keep the middle button pressed), but I can no longer save the image since the render disappears as soon as I lift my finger from the button.
    I've tried merging all scene elements into a new scene (had to rebuilt all my render settings), and it worked for a while, but the problem reappeared after about an hour of playing with RT.
    Other scenes work fine.
    Any idea?
    Check my blog
    Can you send me that scene to vlado@chaosgroup.com so that we can investigate the issue?
      Thanks Vlado. I'll try, it's a big one though, and I'm not sure I can send it with all the textures.
      Also, the problem's disappeared for now. I tried to hide most of the models and do a RT render with just a few elements. When I reverted to the full scene RT was working again as expected. I'll see if the problem returns and send you the scene if it does.
      B
      Check my blog
