Vray RT doesn't start render - Screen error attached
  • Vray RT doesn't start render - Screen error attached
    Hi there,
    I just started a new scene, and I can't launch vrayRT, it does this message.
    I do a close up on a object that is about 10 cm on 10 cm and I have a physical cam at about 40 cm of the subject.
    Could someone enplane me my fault?
    Thanks
    Stan
    3LP Team
    3LP Team
    This should have been fixed in the latest update on our site; it happened with some specific JPG files. If you are still getting the error even with the latest version, can you send me the JPG file in question to vlado@chaosgroup.com ?
      ah haaa,
      well I haven't used the latest VrayRT because I'm on max2008 64Bit and it really doesn't work for me.
      I have a lot of bugs with the SP1 on 2008 (that I have not on max2010) so I uninstall it and reinstalled the 1.50.01 because it was not possible to work with.
      if you want I can make a list when I have time but the first bug that come in my mind is that when I changed the light value, it doesn't updated in RT, and with 1.50.01 it does.
      Thanks
      Stan
      3LP Team
        Yes, please send any problems to me at vlado@chaosgroup.com, otherwise we would never know to fix them.
