Blown out RT vs dark render
  • Blown out RT vs dark render
    Hi There,
    I may be missing something: we used to use RT with Max2009, switched over to Max2011 and for some reason I get this blown out render in the active shade window.
    Lighting setup : daylight system with Vray dome light and exr. It is using a grey vraymaterial as overide material.
    I am using it the same way as previously, but may be missing something silly?
    Can anybody give some suggestions?Click image for larger version
    looks like it could be a gamma setting
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      It seems to be with the dome light. With the dome light switched off, the renders look the same, switch the dome light back on and it gets blown out.
        Are you using the physical camera too?
        Best regards
        Vlado,
          Yes. using the vray camera
            Is the exr gamma set to 1 in the bitmap loader?
            B
            Brett Simms
            www.heavyartillery.com
            e: brett@heavyartillery.com
