Working bad/strange until reset
  • Working bad/strange until reset
    I am working with RT SP2 in max 2009 32 bit with Vray Adv SP5.
    Don't understand why but if i start 3ds max and setup the RT it doesn't work fine until i reset and start again. The problems are creating geometry, draging the mouse normally the geom. is not showed, if i drag very quickly (one fast click) the geom. is showed well (small teapots) [[dont know why one box is showed and the other one no...]]. Problems are either with light... i show the problem here_
    http://www.youtube.com/watch?v=Jja-BLwLaLM
    Thanks for reading,
    BestRegards,
    Can you try this with the V-Ray RT GPU beta (it still includes the CPU renderer)? There was a similar problem that was fixed.
      Fixed with gpu beta using cpu engine(in fact cant use gpu with an Nvidia quadro Fx770m... )
      thanks,
        Actually it should work... you may need to update your GPU drivers though.
