RT 1.90.01 GPU glossiness Bug ?
  • RT 1.90.01 GPU glossiness Bug ?
    Hello,
    I've find something strange on GPU mode if we use a simple Vray material with a map on RGlossiness slot.
    Because picture are more clear than my english, take a look at it
    Without this RGlossiness map, CPU and GPU are done the same job .
    With Rglossiness map, the openCL kernel give some strange square and don't blur ... So it's bluring my reflection at some place if you look carefully ! it's near to work, but it's not fully work and create a strange reflect.
    The Blue matrial isn't identical on GPU and CPU because VrayBlend is unsupported in OpenCL . it's good that Vray wrote this sort of info for us on the active shade
    The GPU is a lot more fastest than CPU, it's not a news But it also give less white Dot !
    So .. back to the strange reflect. It's a bug or an unsupported feature ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    are you using any unsupported maps like berconmaps?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      No, it's a tga
      freelance 3D artist
      www.ghiom.com
        Can you send the scene for this to vlado@chaosgroup.com so that we can fix it?
          Scene sended to you Vlado.
          Thanks you for your support
          freelance 3D artist
          www.ghiom.com
