UPDATE 04-04-2011 Problem solved
Delete the clbin in C:/users/***/AppData/Local/Temp/
Stats (yellow text in the right upper corner) shows a working engine but activeshade window remains black. If I change something in the scene, stats updates, but image remains black. If I switch to CPU RT, it works fine.
Specs are Vray 2.00.02, max 2011 x64, quadro 4000 GPU
A mate of mine did the test with the same scene, same setup (GPU etc.) and did worked fine.
I'm puzzeled by this issue ...
Here'a a screengrab of the problem.
Uploaded with ImageShack.us
