Just upgraded to SP2 on Max 2010, and now Vray RT GPU crashes on anything I try, here's the screen shot.
Vray 2 SP1, RT GPU Crashes everytime
when i was this error, i had delete the clbin file and it's work .
if not , setup again your GPU with the select opencl device for vrayRt utility .
So I noticed that is was working fine in 2012 x64, but still giving me this error in 2010 x86. (both SP1)
If I manually run the RT server from the 2012 install then it works in 2010, but If I let 2010 launch it's own server then it fails with the above message....
It is very likely that the 32-bit version will crash; the current nVidia drivers take about 1.5 GB of RAM to compile our OpenCL code, which is on the verge of the usable memory for a 32-bit application.
