Problem of correct visualization Active shade
  • Problem of correct visualization Active shade
    Hi Vlado. I waited for vray 2.0sp1 but this SP not resolve my problem.
    In the image below (cattura.jpg) you can see my normal settings of gamma correction and LWF.
    "Every Time" that i press ACTIVE SHADE i see the RT image with uncorrect gamma color ( cattura1.jpg).
    So, every time, i have to press the active shade button again (often i have to press 2 or 3 time) and the active shade finally give me the right color and gamma correction(cattura2.jpg).
    I never had this problem with RT before Vray 2.0.
    This happens to me all of the time. It's easy to fix it by just starting a new activeshade render but it is annoying and i'm not sure to see the right result.
    Please help
    Render and Animation - WWW.IMERGO.IT
    Thanks for the pointer; I was not aware of the issue. Will make a note to fix it. By the way, which 3ds Max version are you using?
      I know that i have to upgrade 3dsmax... but i still use Max2009 . ( i will switch to 2011 or 2012 soon).
      I see other people in the forum (Like Dlparisi) have the same problem.
      regards
        I have this problem too. I started a new thread in the "general" section before I saw that other people have the same problem.
        I work with max 2011 and 2012, always the same problem.
        Michael
        Best regards
        Michael Kaiser
          So this is fixed now; if you would like the fix, please email me to vlado@chaosgroup.com
            ok. I write the e-mail now. I'm inside a big job and it will help me a lot.
