RT and DOF broken/
  • RT and DOF broken/
    trying to use vray RT for setting up a keyframed DOF change. when i first dial in any new settings, RT updates as it should.. however if i change to a different frame the DOF disapears. if i adjust the DOF settings it comes back again, or if i re-start RT, but the moment i change frame number, it dissappears again.
    this is using a standard camera and the dof settings in the render dialogue.
    Which V-Ray version is this?
      sp1, x64 max 2011
      seems to be fine with physical camera, so im using that now..
        Thanks for the pointer; will fix it.
