Error during V-Ray RT initialization in stage 2!
  • Error during V-Ray RT initialization in stage 2!
    I keep getting this error and no RT. ????? What is this?Then if I delete some geometry....... RT works. Frustrating.
    Really....... is it that stupid of a question? I thought it was a bitmap performance memory issue. Nope. The scene is small, under a million polys..... Anybody?
      Had the same problem a little while ago.
      It appeared to be a texture issue for me as once texture was changed it worked fine.
      Maybe it's still an issue??....have you tried rendering with a global material override??? This may pinpoint the problem to a texture or geometry.
      Hope this helps
        If you still have issues, it would be best to get us the scene to vray@chaosgroup.com so that we can look at it.
          thanks for the reply. Yes, when I overide it works fine, but thats thing. Is there an issue somewhere with textures? type of texture?
            Some older versions of V-Ray RT had issues with PSD textures; however, this should have been resolved since then...
              Thanks for the reply, no psd textures. How do I email the scene? The zip is 188mb
                Email us to vray@chaosgroup.com and our support guys will let you know how to upload it on our FTP server.
                  Done. Thanks.
                    Thanks. i am uploading my zipped file now called "structural"
                      Any update on the file? Anything.....fustrated. Using my RT with MTL Override is kind of lame. I hope there is something that can be done.
