Vray plane not visible with GPU Vray RT
  • Vray plane not visible with GPU Vray RT
Name:	Vray RT CPU.jpg
ID:	873172Click image for larger version
Name:	Vray RT GPU.jpg
    I've only just got around to trying out Vray RT and on this test scene the vray plane is visible when I use CPU rendering but not when I use GPU rendering. Any ideas? Thanks.
    3ds Max Design 2012
    Vray 2.10.01
    Nvidia GeForce 8800GTS - 270.61
    Anybody? Please.
      Hmmm...apparently it's one of those circumstances in which RT/GPU is not yet supporting anything that creates toplology at render time - like displacement, for instance.
      My best guess...Vlado?
      -Alan
        thanks for the reply alan but there's no mention of it not being supported here:
        http://www.spot3d.com/vray/help/rt10...s.htm#geometry
          Right. That's because the page you reference is specific to RT in general, not just RT/GPU. As you have seen, the Vray plane works just fine in RT/CPU.
          If you look at this page, which is RT/GPU specific: http://www.spot3d.com/vray/help/rt100/render_gpu.htm you'll find this:
          Geometry
          Only triangle meshes are supported.
          Since the Vray plane only creates a renderable surface at render time, I'd imagine that it is not being considered a triangle mesh by RT/GPU.
          I hope they can include it soon, though!
          -Alan
            thanks alan, i missed that. odd that one of vray's most basic elements isn't supported stright away.
