I'm using 2 distributed render servers each with a ATI Firepro 3d v7800 on max 2012 design 64bit vray 2.0 . When I run rt active shade all is well. If I close the active shade window and then try to run it again, both render servers get to "initializing material kernels" and then error out with the V-ray standalone has stopped working error. If i close down the rt render servers on both machines and then start rt render server back up it will run once again. any suggestions would be great.
Kelly
Kelly
