RT crashing on using animated cameras
  • RT crashing on using animated cameras
    Hello fellow Vray users. So im using Vray RT for a project. And I know its really not meant for animation and all. But what I have done is set up key frames for the camera movement from one location of the scene to and other. So all i have to do is cycle thru the time line to get to the next view and not have to navigate to the next location. Everything works fine in my scene cept for when I toggle on my layers for my cars. And it works every now and then when i toggle thru the timeline. But usually its hit and miss when it does work (resulting in a crash). Are there some things that Vray RT is incompatible with? Maybe I'm using a material that it doesnt like on the cars?. If so are there some known materials that I should stay away from when using Vray RT? But heres the thing about it...If I navigate thru the scene its fine. No crashes or anything. I can look around the scene and not worry about it crashing. Any suggestions are appreciated..
    Thanks,
    Alex
    Can you get me some more specific reproduction steps (a scene would be useful too)? I suppose something goes wrong when going to a different layer, but I don't know how your scene is set up.
      Thanks for the reply vlado... Yeah I have to confirm its okay to send the file. Got pulled of the project but as soon as I start back on it I'll see if I can get a file for you.
