Not sure if this is possible, but is it possible to tell VrayRT GPU to only use, for example, 75% off the cards power so that my other open apps don't lag so much?
GPU card limiting
GPU card limiting
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
from spot3d
Balancing the GPU load
If you have only one GPU on your system, you may find that the user interface becomes sluggish and unresponsive while V-Ray RT is rendering on the GPU. To alleviate this problem, reduce the Rays per pixel and/or the Ray bundle size parameters in the Performance section of the V-Ray RT renderer settings in the 3ds Max Render Setup dialog. For example, you can try values like 128/8 or 128/4. This will break up the data passed to the GPU into smaller chunks, so that the user interface requests can be processed faster. Note however, that this will reduce the rendering speed. Turn on the statistics display to check the difference in render speed and to find the optimal settings for your system.
hope it helpsAlessandro
hope it helpsKind Regards,
Richard Birket
