Vray RT 2.2 3dsmax 2012 64bit, multiple spotlights with projector maps dont work?
  • Vray RT 2.2 3dsmax 2012 64bit, multiple spotlights with projector maps dont work?
    Hi all
    As the title says. If I create a spot light with a gradient in the projector maps, RT works fine with this. If I then create a second spotlight with a projector map, only one works at a time, the other looks like it starts tiling the projection map. Is this fixed in 2.3?
    Thanks
    Will.
    Hello,
    We reproduced the issue and made a note about fixing it.
    It persist in the latest version also.
    Thank you for the feedback.
    Tashko Zashev | chaos.com
      Thanks Tashko, could you please update this thread when/if fixed, even in nightlies. I dont like test rendering in normal vray anymo
